メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Toshiba 40PB200は、PB200シリーズの40インチ薄型テレビです。2012年に発売されました。
Why is my TV blinking?
We have a Toshiba flat screen LCD that constantly blinks -- goes dark for a half second like the LEDs are turning on or off. Changing the picture mode can alter the rate of blinking but I cannot get it to stop altogether (although this has worked in the past). Any suggestions on how to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
8 件のコメント
So do you have to get a new tv
さんによる
I've been having this issue about a month now. It comes and goes...so I'm a bit confused. Ant solutions? Or suggestions to self check before taking it to be repaired?
さんによる
I’m not seeing a way to adjust the setting without the TV remote… Is that true?
さんによる
I raised my back light to 100 and it started blinking faster as I went up. I lowered it to 60 and there’s no blinking
さんによる
How can u adjust the back light I've tried won't let me
さんによる
3件以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
@alf222 let us know the exact model of your TV. If it is the screen that is blinking it is possible that you have a bad power board/LED driver or a bad LED array. Post some good images of all of your boards with your question so that we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that.
Update 01/19/2024
Just to clarify why decreasing the backlight will work (for a while). As one decreases the brightness, the voltages to the backlight strips will decrease. Less power = less heat. That will keep those strips illuminated for longer. This may or may not work for a while. For a permanent repair, the backlight strips that will require replacement.
このアンサーは役に立ちましたか?
スコア 7
6 件のコメント:
@alf222 Thank you, lowering the back light and then raising it to 80 (too chicken to go higher) worked, no more flashing on and off picture
さんによる
I have a 2 1/2 year old Toshiba that blinks on and off. How do I reduce the numbers spoken about above.
さんによる
I've got a 50 inch Toshiba telly in mind links as well he actually gets on your nerves after a bit and it's only 3 years old I don't know what to do about it either I'll try turning my back light down to 18 see if that works but if anybody else has got any suggestions what it might be won't mind knowing also just go out and buy a new telly and not a Toshiba one this time or all tell us the same thank you
さんによる
I just fixed a 70 inch Vizio with this problem. It was a dead completely shorted diode on the power supply for the backlight driver. Since this problem can often be fixed by turning the brightness down it is almost certainly either the power supply or the LED strips inside the display panel. I would start with the power supply first though.
さんによる
It appears that adjusting the back light worked like a charm! I did notice that changing the 'Picture Mode' from ie Movie, PC etc to Gaming helped reduce the blinking on my TV (yours might need to be adjusted to one that works for you).
さんによる
1以上のコメントを表示
コメントを追加
One of the chips is overheating. Use freeze spray to identify it, unsolder the heat sink, clean well, then use a good heat sink paste and resolder the heat sink back on. You can try turning the backlight down in picture settings as well. Menu-picture-Backlight. It is factory set at 100. Try turning it down to 50, then bump it up by 5 until the picture blinks. Bump it down 10 or 20 from there.
このアンサーは役に立ちましたか?
スコア 5
6 件のコメント:
Amazing. Everywhere else said I needed a repair. I lowered mine from 100 to 80 and it stopped blinking. Its a little dimmer and I will probably still need to get the repair at some time but this will work well for now.
さんによる
I turned the backlight down it worked
I turned the backlight down then reset the picture it worked on mine.
さんによる
I turned the backlight down on my 50inch toshiba and it worked
さんによる
Mine is toshiba with roku. Decreasing brightness helps.
i have also fixed before by cleaning. Take the back off, vacuum inlet filters, use a soft brush on all exposed surfaces to remove dust while vacuuming.
さんによる
I have a Toshiba. Flickering was driving me nuts. Lowered my backlight to 54, flashing stopped! Fingers crossed, l hope this is a permanent fix.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Mike Fuhr さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 16
過去 30 日: 80
今までの合計 47,635
