Can it be fixed?
The end of the power cord built into the case broke off into my phone, can it be put back onto my case to make it work?
Hello,
This is a tricky question because the battery case itself requires you to break into it and that is usually the end of it being usefully again as you need to slice through the rubber. If you are willing to do that anyway the charging port can be replaced as its a separate unit but you would have to search online on eBay and other websites to see if these parts are for sale.
I have linked the ifixit guide so you can have a look at how this can be done but if you are not comfortable in repairing these types of electronics I would stick with buying a new case.
Hopefully that helped
このアンサーは役に立ちましたか?
应该可以,前提是你没有拆坏。
このアンサーは役に立ちましたか?
@cjn4rfmat53xq9x Well, you'll break it either way, as shown in the teardown.
English -> Chinese (Simplified)
@cjn4rfmat53xq9x 嗯,反正拆解过程显示,无论怎么做你都会把它弄坏。
過去 24時間: 1
過去 7 日: 2
過去 30 日: 28
今までの合計 1,184
@oliviaguztin post some pictures so we can see what all of this looks like. Use this guide iFixitでの質問に画像を追加する方法 for that
oldturkey03 さんによる 共有
