How do I downgrade back to IOS 10 from IOS 11.2.1
how do i install an unsigned firmware (IOS 10) to my iphone 6S running on IOS 11.2.1
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Unfortunately, it is no longer possible to downgrade your iOS to version 10.X as Apple is only signing the 11.2.X version at this time unless you had previously saved your SHSH2 Blob (see this article on GadgetHacks).
このアンサーは役に立ちましたか?
While update firmware the modem firmware also upgraded so, downgrade is not possible on.
このアンサーは役に立ちましたか?
Apple has already turned off servers that digitally signed iOS 10 to allow for installation. Without this signature it is impossible to install iOS 10. If you used tiny umbrella to save those already signed signatures, you would still be able to downgrade to iOS 9 because the way the iOS signing occurred differently.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 6,659
1件のコメント
Since you are already so far in IOS 11, the only way to downgrade would be to jailbreak. Which potentially, could risk you to mess up your software to the point where your phone is unusable.
Joseph Boehm さんによる
