メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
Stuck on Samsung Galaxy tab 2 10.1 logo
My tablet is stuck on Samsung galaxy tab 2 10.1 logo I can't do a reset but I can do a Odin I can't do a reset because when I hold down the power button and it turned off it will open again stuck on the logo again and if I try it in Odin it goes to the options but factory reset can't I tried the hold the power button and volume up and remove power button and hold the volume up and it will do the Samsung logo and at the top left there will be a recovery booting its color blue but after that it will go to the Samsung galaxy tab 2 10.1 again and if I do the same thing the same thing will happen again
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Hi @laizander ,
Try disconnecting the battery from the tablet's systemboard for a few minutes. Then reconnect it and try a reset. (You only have to disconnect the battery connect cable, you do not have to remove it from the tablet)
Here is a link to the ifixit Samsung Galaxy Tab 2 10.1 Battery Replacement guide which may be of some help
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
you can try accessing the reset menu by holding a power and volume up or down. not sure which one. you can try a factory reset that way. you could also try flashing the stock firmware to see if it is a problem the software.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Laizander さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 4,748
