メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Amigoは、3年間の休止期間を経て、再設計されたRodeoとともに第2世代モデルとして1998年に米国で復活しました。
What can I replace the original engine with?
So long story short. My timing belt a couple of years ago broke, resulting in the pistons colliding and damaging the cylinders. I had the pistons re-machined but she failed the state inspection due to weak cylinders. I plan on replacing the piston rings as a first step but was wondering as a last ditch effort can i replace the engine entirely. Therein lies the question. Should i replace it with one of the same make, model, and year. Or can i use a different one entirely.
1998 Isuzu Amigo 150,121 miles
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Daniel Choate if you stick with the same model and year you do not have to worry about potentially having to find brackets mounts etc. to fit the engine. So that would be the easiest. You can most likely use different years for as long as it is the same series. Your 1998 should have the same setup, brackets and mounts right to the 2004 model year and should be a straight forward swap.
You can of course swap some other GM engine into your Isuzu but that get's a bit more involved. It will all depend on your abilities, tools etc.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Daniel Choate さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 26
今までの合計 1,479
