How to remove prong from external speaker jack
male rca jack broke off inside female rca on rear panel. how do i get it out?
@budlight use a drill bit just a bit smaller than the center pin and use either your fingers or a hand drill to gently advance the bit into the pin. Once the bit binds inside the pin you can pulll it out. It'll take a bit of practice and some fiddling but it'll work. Stay away from any kind of power tools since that can destroy the board connector.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 177
