メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
745回答 すべてを表示
spilled juice and keyboard back light is little dark
I bought new macbook pro 13" few days ago.. and spilled orange juice on keyboard.
now backlight is little darker than first time(only left side)
then i called apple, they said it could cost $700.00 at least.
so far problem is only keyboard backlight.
so im thinking im going to fix myself.
which part i should get on this site..
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Before you spend a lot of money, I would invest some time following the iFixit guide for your model and disassembling the laptop as much as necessary in order to clean out all the orange juice with q-tips dipped in rubbing alcohol. A substance like orange juice can continue to cause more problems down the road, and getting it out of the computer can prevent this, and even alleviate issues you are experiencing if you are lucky. Once you've cleaned it out, you can then evaluate what remaining problems still exist, if any, and whether you want to pursue correcting them. I just think that it is premature to buy replacement parts when you still have a substance in your computer that is toxic and needs to come out.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
ok i asked my husband to do this. he went to get some tools. we r going to clean these parts first. i will comment later again. thank u all
さんによる
コメントを追加
Sounds like they want to replace the logic board, I think you should follow rdlkincorpoated's advice for cleaning the keyboard, an if the part has just been destroyed by the liquid, then you'll have to replace it for $300. Of course since the light hasn't completely shorted out, you can probably still clean it, and it'll be just fine. If not, well, you can part with $300 (a lot better than 700 though!) or just live with it.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
To restore keyboard lightning you have to open the machine, take off the logic board and reach the keyboard layers to clean them. $700 to do this job is a ripoff IMHO...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Michiko さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 6
今までの合計 3,180
