メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ASUS ZenPad 3S 10は、ASUSが2015年10月に発売したZenPadシリーズの9.7インチタブレットです。モデル番号:P027。
Tablet will not turn on.
Tablet will not turn on. Charging does not help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 20
17 件のコメント
does it show anything on the screen when the charger is connected
さんによる
No, black screen
さんによる
PC show anything when connected ?
さんによる
No seems completely dead
さんによる
My Zenpad won't come on doing the 60sec or unplug what else I can do.
さんによる
12件以上のコメントを表示
コメントを追加
19件の回答
ベストアンサー
Unplug device. Hold down power button for 60 seconds and then let go of it. Plug in the power cord. Now hold down the power button a few seconds and it will (should) come on. Worked for my Zenpad 3s 10.
I had been playing game and folded the case cover over and headed into a meeting, battery was @85%...3 hours later I returned to find the tablet dead and not appearing to charge/turn on at all. So I googled for a few minutes and found the 60-sec power button and charge cord & then power button trick. Power shows 68% on the tablet now so it actually never drained....must have just frozen in the game or something???
このアンサーは役に立ちましたか?
スコア 60
46 件のコメント:
eqtoasted Thank you it worked for me <3
さんによる
I'm having the same issue although none of the fixes I've found seem to be working. When I plug my tablet in I get the battery icon with the lightning bolt in the middle (like it has no charge) then I immediately get the battery icon that shows a full charge. Then a blank screen and nothing happens. Very frustrating. Tablet is only weeks old. I will be returning it for a replacement.
さんによる
Thank you EQTOASTED, that worked for me as well. Maybe put it in the freakin manual? Ha.
さんによる
And it worked for me. T H A N K S ! ! ! ! !
さんによる
Yep - worked for me - well done!
さんによる
41件以上のコメントを表示
コメントを追加
Try a hard reset using Recovery Mode. NOTE: THIS WILL DELETE ALL DATA.
Turn off your device by pressing Power button.
Hold down Volume Down + Power key.
As soon as menu appears, release all the buttons.
Navigate to "wipe data/factory reset"Reset with Volume Up and Volume Down keys. Use Power button to select.
Choose option "Yes--delete all user data".
To reboot select "reboot system now".
You have just completed hard reset process.
If this works, please up my reputation.
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
Tablet won't turn on to do a hard reset. Just black screen
さんによる
@eqtoasted, It worked for me also. Thanks.
さんによる
Thank you!!! I was in panic mode. This fixed it
さんによる
Worked like a charm. Thank You!
さんによる
thankyou worked perfectly such a clear way of explaining
さんによる
コメントを追加
Holding the power button down 60 seconds turns the device off even if frozen. I got stuck at a flickering blank screen while watching FB videos.
I have no idea why it did what it did, battery shouldn't have been dead either but now it's charging, giving me a charging symbol, but won't turn on.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Oh thank G-d, this worked.. I was pressing & holding the power button and the volume down and then power button and nothing was happening, just the white light.. I plugged it in like you said and counted out 60 seconds.. after around 35-40 seconds the green battery with a + over it came up and I kept holding.. when I finally let go the light on the top turned red and the white light by the screen had turned off.. I pressed the power button normal after this and the Asus logo came up and started to boot as normal.. everything is working now.. but whyyyy did this happen? Could it be from someone using the charger for a phone??
さんによる
コメントを追加
I was in the same position as reported by Jim Fournier, above: ‘I'm having the same issue although none of the fixes I've found seem to be working. When I plug my tablet in I get the battery icon with the lightning bolt in the middle (like it has no charge) then I immediately get the battery icon that shows a full charge. Then a blank screen and nothing happens. ‘
Spent hours trying key combinations both whilst charging and with cable out. Eventually got a bios-style menu with 3 boot options. Chose Normal Boot and all was well again. Hooray!
The key combination was either Volume Down + Power or Volume Down + Power + Home and I did this while there was some sign of life i.e. when the charging level was showing.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thank you! Totally worked, and I was about to throw my tablet against a wall
さんによる
Update: works every time. Simply press volume down and power buttons together having just inserted the charging cable.
さんによる
コメントを追加
Got to be battery, charger, cord,outlet, in that order. My first 10s was a brick.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had the issue of my ZenPad not charging after a small drop. Also the home button stopped working. When i tried to power up, a low battery icon appeared briefly but nothing happened. Hard resets did not work.
The reason in my case was a disconnected ribbon cable inside the tablet and was quite easy to put right.
You need to take the metal back off the device, first make sure the sd card tray is out, and remove the 2 little screws either side of the usb port. Then use a prying tool or similar (I used guitar plectrums) to ease the screen and metal case apart. It comes off quite easily once you get started, just take your time.
Once the back was off it was immediately obvious that the left hand ribbon cable was unseated from it's port. once the connection was restored, the metal case clipped back on and everything was working again.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you for your input. That was exactly the same thing what happened with my tablet. Strange that the battery was 87% but won't reset without even a brief charging. To my surprise it was still drawing approximately 200mA off the charger without the ribbon in the socket. Nb this tablet is still going strong despite seven years and counting.
さんによる
コメントを追加
This worked for mine. I closed the cover last night after a game and it wouldn't come on today. I held the power button for about 10 seconds and plugged it in. The batter indicator came up at 65% then booted when I hit power.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If I reformat my device will the screen stop locking like that
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I got mine brand new 4 days ago and already having the same issue. None of the steps worked. The tablet turned off while using it, fyi, it was fully charged, and would not power back on. Asus has a lot of tablets that do this very same thing. I should had known better. But I thought zen motion would help with that issue, but that tap twice crap dont work either. I think their android tablets are flat out no good. I am sticking with iPad or samsung. Fyi the casing around the tablet is not even put together well, its loose. Smh. Get it together asus. Your gaming laptops are amazing but anything to do with touch screens are awful..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The fix supplied by Eqtoasted worked for me with a twist. I held the power on/off button for 60 sec. , then tapped the same button and the unit responded and powered on. No attaching to the power cord.
Just a little twist, THANKS Eqtoasted!!!
It worked, sort of but It Worked!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my zen thing was stalling on startup.
Holding Vol+ and POWER for about 15-25 seconds launched a screen (finally! its alive!) and after trying REBOOT first (to no avail), I finally tried RECOVERY and that resulted in an error so finally tried WIPE DATA which has worked, now my asus tablet will start up all the way!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The same thing is happening to me.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hold power button for 60 sec. Then plug it in to charge. it should work.
さんによる
A few mond ago i also had the same problem my son was watching yt when he has been fallen a sleep i took it forgot to close the app when after a few ours i pikked it up it did nothing! But amazingingly after a few days trying it just worked again. Now 6 months later my tablet asus zen tab 3s 10 again doesn't respond...... after your instruction it shows when i hold de power button for 60 sec down every 10 sec a glimp of an empty battery in the middle of the screen and 1 sec later it dissapeares again. The battery sign is in middle of the screen and only the bottom milimeter is red colored rest looks empty but its stil not charging. Help does someone have any othe instruction. Cable and adapter are both fibe i'll already checked! ?????
さんによる
コメントを追加
Hi, my tablet turned off with 75% battery, i’ve tried EVERYTHING.
Soft reset (didn’t turn on)
Hard reset (didn’t turn on)
I even unplugged the battery like 20 times (didn’t turn on either), and out of frustration, tried to softly scratch the battery conector pins, to release any charge remaining.
After that the tablet turned on and life was great, until i assembled the back on, then it turned off and couldn’t turn it on since. Before it turned off i catched a glance of the % battery remaining, and it had 70% so it’s not a battery thing.
I’ve come to the conclussion that the tablet is somewhat stuck, but i can’t turn it back on.
Please somebody help me hahaha
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My AsusZen pad 8, i m accessing is around one year back now. I charge it for around 3-4 hours and tried to restart it, but Its took around 20-25 minutes to displaying Asus logo and near about 3 hours to display screen lock. Unfortunately i didnt remember the password so trying to reset password with power + volumn down button. Its not again its taking a lot of time and its not loading. After several attempt its displaying Asus logo.
Can any one help me how to reset screen lock or by pass that. Tried to attempt wrong ping, but forget pin/reset pin is not displaying.
Please
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
After falling on the ground, my Zenpad wouldn’t turn on, nor give any sign of live when plugged to charger or the PC.
I tried the 60s trick, and IT WORKED!
Thanks a lot!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Took the back cover off, and disconnected the battery, now it works like a cham
U need to glue the back cover again though
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
THANK YOU!
My Asus EeeBook just wouldn't start, whatever I tried. Until I saw your post, and did what you suggested (delightfully simple instructions - I'm tech challenged ) and watched with great relief as the black screen lit up! (the battery was on empty and apparently was not charging with a black screen). This saved me an expensive visit by a computer technician.
Solution tried: Unplug device. Hold down power button for 60 seconds and then let go of it. Plug in the power cord. Now hold down the power button a few seconds and it will (should) come on. Worked to start my 6 year old Asus EeeBook (!)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Asus zenpad won't turn on. I tried every solutions. Asus was not used a wile i charged it for 12h, battery is 4.1V. Non of the.combination work. What can i doo?????
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Jedyne rozwiązanie to naciskanie guziczków? Nic nie działa. Tablet nie wyświetla nic jak podłącze ładowarkę, nie wibruje, nic kompletnie nie pomaga. Co padła płyta lub raczej jakiś jej element. Może jest tu jakiś elektronik co potrafi to naprawić. Czy tylko tacy co każą naciskać przyciski?
さんによる
コメントを追加
check your connector battery
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
original question was asked 7 years ago
さんによる
コメントを追加
回答を追加する
Chris Bechtold さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 63
今までの合計 56,024
