Iron not powering on
My Iron is plugged in and is still not powering on or heating up, could the cord be broken?
Open it up using this guide and then use a multimeter to test it:
このアンサーは役に立ちましたか?
Would you be willing to work on an iron?
This Happens sometime, If you forgot to switch off your iron it get over heated and may melt the wire of circuits of the iron. I have gone through it, Do check your Wires properly. Also check the power wire fwether it get burned out or not. You may need to replace whole wire.
In case you are planning to buy Get it here: - Best Steam Irons in market
このアンサーは役に立ちましたか?
If you know someone who would be willing to work on an iron, I would like to mail it to them and pay for the service. Thank you, Stephanie
過去 24時間: 1
過去 7 日: 8
過去 30 日: 52
今までの合計 7,101
