メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月に発表され、同年4月10日に発売されました。Galaxy S6 Edgeは Samsungの最新のスマートフォンで曲面ディスプレイをもつデバイスです。
Samsung S6 Edge Sudden Battery Drain
When my phone gets to 60% battery, it suddenly starts searching for service, then the battery dies and the phone shuts off.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
ベストアンサー
I only see these cases occur when people over charge the unit. Usually, they leave their phone charging over night and/or they constantly charge their phone despite not being low.
Back up the device, and perform a reset. Use Samsung Smart Switch for backing up.
Before resetting make sure you know your passwords for google/samsung account.
Hold the Power Button, Home, and Vol Up and you will see the samsung logo appear, let go of the home button and hold on to the power and vol .up button until you see the Android Mascot. Run the factory reset.
After resetting, let your phone charge to 100% and stop charging it until you runs the battery dry. Charge again once dead to 100% and just run it throughout the day. *there is not time span, just monitor the battery percentage as it's being consumed.
I typically run youtube videos back to back.
Hope this helps.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Starting this weekend, I have the same issue - except for the "searching for service" message, and the phone gets to 40-50% battery remaining before suddenly dropping to 0% and shutting down. I did a full reset and had the battery replaced about a month ago. Ever since, I've been carefully following our battery care tips (What to do with a swollen battery).
Do you have any other suggestions or recommend I do what's outlined above?
さんによる 共有
コメントを追加
If juax's suggestions don't work, consider replacing the battery.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I don't think it is the battery, I have checked it and it is good. This problem only happens when the phone suddenly starts searching for service
さんによる 共有
Mine was doing same thing and I had to change battery . Fixed it.
さんによる 共有
コメントを追加
This is a somewhat known issue caused by an update. So far, the best fix is to see if there are any apps that need to be updated, if so, update them. There’s not much you can do about it yet.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Samsung Galaxy S6 is one of the Galaxy phones with non-removable batteries. Also, users have reported their concern about the fast battery draining on their Samsung Galaxy S6 phones. A fast battery drain on Samsung phones is quite common and there could be several reasons behind that.
Tips to fix Samsung Battey Fast Draining
  • Get rid of Resource eating apps
  • Close the recent apps
  • Ensure Proper Reception
  • Check for Malware and Spyware
  • Disable Notifications
  • Disable System apps like Bixby and S-pay
  • Use Power Saving Mode
  • Turn off background sync
  • Disable unused radios
  • Keep screen brightness in check
  • Factory Reset the Galaxy
  • Buy a Battery Pack
Source: https://fixyourandroid.com/fix/fix-samsu...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
%#*@.I bought a really nice S6 last night off Facebook marketplace for $25 and was so happy till it drained within an hour.Its beautiful to look at tho.
さんによる 共有
コメントを追加
what is the fault when your samsung galaxy s6 edge battery is draining fast
+14
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ARlene さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 15,252
