メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Shure SM58-LC ダイナミック・カーディオイド・ボーカルマイクの修理ガイドです。
Suddenly very thin sound.
One of my (5) SM 58 mics suddenly seems to have lost all bottomend- sounds thin and a bit tinny. Same cable/ input all other mics fuller sound. More out put. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
最も参考になった回答
This is an old post but thought I’d give it a go. I had the same thing. Considered the mic lost so I investigated. I found that a piece of the grey foam circle on the capsule (so inside the mic after you remove the spherical guard) had lodged itself in one of the holes in the membrane guard. The foam was deteriorating and getting stuck between the membrane and the black plastic cover. I carefully cleaned it with a can of electronics cleaner and a careful shot of compressed air, being extremely careful to not damage the thin transparent membrane. The mic was as good as new. I did not replace the small foam disc but I don’t notice any difference. Not sure if this helps but mine is fine now. Still working fine 3 months later. Good luck!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
This just saved my SM58. Thank you! That foam bit was perished in mine too. I just crumbled it away with my thumb then gave it a blow. So not as careful as you, but seems to have fixed the problem anyway!
さんによる
Just signed up to say thank you! Saved my SM58 from a trip to the repair shop!
さんによる
コメントを追加
It sounds like something has gone wrong with the cartridge. There's really no repairing the cartridge, so your best solution is to send the mic to Shure for repair/replacement. www.shure.com/service
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I opened up the microphone and it wasn't connected to the base. if this is the problem, go to your nearest fix store
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Davids Grendze さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 49
今までの合計 4,295
