メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
住宅の電気設備は、家屋に電力を供給し、さまざまなコンセント、家電製品、照明器具に分配する複雑な電気部品のシステムです。
What kind of bit could I use
Where can I find a proper bit for this kind of screw?
画像
These screws on the bottom of the battery case
Update (11/15/2017)
This power cord is produced by a Czech company Emos model HE1313 (E1313).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
That appears to be a security type of screw. Please tell us the make and model number of what it's on.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Here's the bit you'll need: Tri-Groove-Nut-Driver 1/4" socket
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you, but I'm not sure if the screw hole is wide enough for this bit.
http://nevada.pl/power_cord_screw2.jpg
http://nevada.pl/power_cord_screw3.jpg
Seems to be smaller than 1/4"
さんによる
コメントを追加
This type of screw seems to be common in power strips in (some parts of) Europe. Its head is only about 5mm in diameter at its thickest, and they tend to be seated quite deeply within the power strips, making extraction difficult. It also seems to be a genuine “security” screw because it really is difficult to find a driver for it. The closest match in dimensions seems to be the “#6” tri-groove socket that’s sold in the US, but on the pictures it appears too thick to fit the deep screw holes in these power strips.
I’d managed to drive it with snake-eyes but it wasn’t efficient and it definitely won’t work for fastening it back into place.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes, but it would be nice to find a source for this socket. Do you know of the kneedle points of a ring expander would work?
さんによる
コメントを追加
回答を追加する
Driver さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 15
今までの合計 1,040
