メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony製DVDプレーヤーの修理および分解ガイド。
DVD door will not open
This model is RDR-VX515, VCR/DVD recorder combo. When I press the eject button I hear a noise as if the ejection process has begun. Then the tray does not open and I get the message "LOAD" as if the tray has opened and I have closed it. The next message is "NO DISC."
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
I would take the cover off, then plug it in and press the eject button to see whats preventing it from opening. Sometimes the mechanism that holds the DVD in place can get stuck, or something could be jammed in that whole mechanism chain ... you'll see what i'm talking about when you observe it with the cover off. You should not need to take anything apart ... just watch it when you try to eject and the cause of it should be obvious. Post back if you can't figure it out or you see something and don't know how to handle it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This is a Wonnie DVD player, the DVD door is opened by pressing on the door. There is no eject button.
さんによる
コメントを追加
回答を追加する
Glenn Stoops さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 5
過去 30 日: 44
今までの合計 4,141
