Wheel on upside down
I installed one of the front wheels upside down. How can I remove and put it the correct way?
Take the wheel off by reversing what you did to put it on. Turn the wheel around and put it back on.
このアンサーは役に立ちましたか?
These guide may prove helpful
If it is a front wheel, there are two black plastic tabs, one in the front, and one in the back. Use a large pair of vise grips or pump handles to gently depress both tabs at the same time, and the wheel will slip right off. reverse teh arrow and reinstall the correct direction.
このアンサーは役に立ちましたか?
Get someone strong basically cause im still tryng to get it off…..2 weeks riding crooked…
このアンサーは役に立ちましたか?
I did the same thing and vice grips are the solution, but it takes a few tries. Don’t give up!
このアンサーは役に立ちましたか?
I don't have vice grips
過去 24時間: 1
過去 7 日: 3
過去 30 日: 30
今までの合計 11,452
