メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How do I exit DnX mode?
While trying to reboot my tablet I believe I did something wrong and now all it shows is
Entering DnX mode.
Waiting for fastboot command...
How do I exit this mode? I tried holding the power button but it just goes right back to this.
It's a Nextbook Ares 8
Model number NXA8QC116R
Any help would be appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
10 件のコメント
Same here some times it would turn on and it would be in safe mode and 5 minutes later it would shut down and show its battery charging picture with a ? In it and it would say battery unknown and go back in dnx mode and it seems like every time you put a micro sd card in it goes in dnx mode and if u take it out it will not turn on or work at all until you put the sd card back in right now I am on my computer.
さんによる
Can you download an app for it
さんによる
I have a ares 8 and need help. The TWRP is not working also fastboot commands are denied. las3@nauta.cu
さんによる
Mine still won’t work! I don’t know what to do!
Can someone tell me what to do? I tried everything!
さんによる
Next book ares 8a dnx fastboot mode
さんによる
5件以上のコメントを表示
コメントを追加
7件の回答
ベストアンサー
Try this,
- Hold volume up for 15 Seconds,
-While holding volume up, press and hold the power button until tablet turns off
-Release volume up button
-Release Power Button
このアンサーは役に立ちましたか?
スコア 14
12 件のコメント:
I did that and it turned off, but I didn't see the Nextbook logo like I usually do when it shutdown and when I turned it back on it still said Entering DnX mode.
さんによる
this didn't work for me
さんによる
Worked on my Lenovo Yoga Book. Thanks!
さんによる
my nextbook is doing the same, when it does this, on a computer, when you plug it in to the computer, it will say that a driver is unavailable. that means that somehow, you'll have to install a driver, which could brick the tablet if not done right.
さんによる
Yay!! It worked on my Ares 10. I wish I could reset to factory, but that is how I ended up with the DNX mode...
さんによる
7件以上のコメントを表示
コメントを追加
To get to recovery power on, once nextbook logo appears push and hold volume down. When you select recovery and push power to select, it will come up with a droid and exclamation mark says no command, hold power and push volume up at same time and release. This takes you to menu to wipe cache and reset to factory! Hope this helps!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I spent 4 hours looking for this answer , you get a gold star and should move to the head of the class
さんによる
コメントを追加
What I did was hold down volume up and power until it goes to a black screen then hold down the volume up and power button while it try to boot you will then see the screen shown below should be a recovery screen use volume up and down to navigate and use the power button to then select reboot system now it’s should then have some yellow text at the bottom and boot up
画像
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
So I found out that there's no fixing it,cause the OS has been erased,which means…you'll want a new tablet(unless bricked tablets are your thing)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Worked thank you so much
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I get to the Android and exclamation mark with ‘no command’. Continue as instructed. The nextbook powers down and I have to power it back up. It returns to the password screen with no change.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
that was all my carot time &&^&@*@!!!!!!!!!!1
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Josh さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 48
今までの合計 23,450
