Drone will not connect to controler
Tried local drone store no fix there awnser was send it back to manufacturer ( zero) not shure how to go about that every thing normal untill start up drone not conecting to controller
Well, first ... please identify the make and model of the drone you are asking about to help us assist you better
このアンサーは役に立ちましたか?
It's polite to state a reason for giving a down vote. Otherwise it's like sticking your dogs nose in it and saying NO. The dog thinks, yes it's mine, yes I see it here, now it's on my nose, what am I supposed to do?
Also this is a comment, not an answer. Maybe I should stick your nose in it for leaving it in the wrong place ;-)
You must know how to help with his issue since you are here, yes?
You may have a problem with your motherboard as far as connection goes or with Bluetooth connection. You can try to look at this guide even though it is for a different drone. It still might help! Yuneec Breeze 4K Motherboard Replacement.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 59
