メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus X200CAは11.6インチで、重量は1.2kg(2.6ポンド)のノートパソコンです。Intel® Core™ i3 3217Uプロセッサ、Intel® ULV Pentium® 2117Uプロセッサ、またはIntel® Celeron® 1007Uプロセッサを搭載し、RAMは2GBまたは4GB、ストレージは320GBから1TBまで選択可能です。OSはWindows 8で、HDウェブカメラを内蔵しており、バッテリー駆動時間は約3時間です。
Keyboard is not responding?
Some of the keys do not type.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Fixing individual keys is not usually possible, but a complete new keyboard is not that expensive and quite easy to fit. Make sure you get one of the right nationality (US, UK etc as appropriate) and do a google search for Asus X200CA keyboard replacement for a guide. From a quick glance it looks like there are one or two screws on the bottom of the laptop that you have to remove, then there are a few tabs, probably along the top of the keyboard, that you have to release with a spatula or thin knife to allow the keyboard to be lifted out.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Keys are Stuck
There might be crumbs stuck inside your keyboard. Try holding your laptop upside down or at a 45 degree angle from being horizontal and give it a few good shakes that will dislodge anything stuck between your keys. Use a keyboard vacuum or a can of compressed air, these can help to remove any particles in between the keys interfering with its usability.
Loose Cable
The ribbon cable connected to the keyboard may have come loose. Fix this by reconnecting the cable.
Water Damage
If you spilled any liquids, especially soda that can get sticky when dried, apply some cleaning solution, such as rubbing alcohol or soapy water, to a dish towel and gently rub down the affected keys. You can also remove keys and wipe it from the inside.
If those methods are not applicable, try rebooting your computer. If none of these work, try replacing the keyboard.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Maricarmen Garcia さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 21
今までの合計 758
