メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
Parts repair list for front replacement screen?
Hi,
Could someone please provide me with a complete list of all the proper Parts, trim adhesive, & any NEW special tools I will need to repair a full front replacement screen on a iPhone 7 White A1660 Verizon phone?
I've done 20 or so iPhone 6, 6+ replacements, but this is my first iPhone 7. I noticed when opening the phone it has a section of White gasket adhesive at each end and some black trim adhesive on each side running the length of the phone, what is the easiest way to buy the trim adhesive kits for ease of installition.
I also see I need to purchase a new Y000 screwdriver, but I'd like to know I bought all the things I need the first time to do a screen replacement the right way the first time.
I'm buying the full replacement screen, but I don't think they come with the home button, I assume I'll transfer mine over to the new screen, am I correct on this? Is it a tough job other than warming the adhesive to loosen it ? Any Gasketsetc needed?
Thanks for any help on this.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@kongfish you are correct. You'll have to transfer your home button. Here are the guides iPhone 7 のスクリーンの交換 and for the adhesive right here iPhoneディスプレイ用接着剤の交換 The parts are available here iPhone 7 Screen and here iPhone 7 Display Assembly Adhesive
This custom cut adhesive film secures the front screen display assembly to the case of an iPhone 7.の画像
製品
Replace a screen compatible with iPhone 7. Includes all of the small parts preinstalled in the assembly. Features a 4.7 inch 750 x 1334 pixel IPS LCD Display, Front Glass Digitizer Panel, Front Camera Assembly, Earpiece Speaker, and LCD Shield Plate.の画像
製品
iPhone 7 Screen
$55.99
iPhone 7 スクリーンの画像
ガイド
iPhone 7 のスクリーンの交換
難易度:
中レベル
30 minutes - 1 hour
iPhone ディスプレイ用接着剤の画像
ガイド
iPhoneディスプレイ用接着剤の交換
難易度:
中レベル
1 hour
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Gary さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 101
