メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
774回答 すべてを表示
My MacBook Chargin Port burnt
Hello I am using macbook from 2015 , after sometime my macbook charger stopped workign so i went to apple store and got a replacement but after some more time it stopped working charging pins were pushed down , and it happened to 3rd charger too ,
unlucky me i am using 4th charger now , and it my mac's charging port is kindda burnt also ,
So can anyone tell me from where to buy , and how i can i install it myself ,
Also a new original charger very cheap, i am tried of charging chargers .
thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
I would review this Apple T/N: Apple Portables: Troubleshooting MagSafe adapters to make sure your charger is in good shape!
As for the charger its self... Review these many cheap units are fake units!:
- Counterfeit Macbook charger teardown: convincing outside but dangerous inside
- Lacking safety features, cheap MacBook chargers create big sparks
Many of these cheap clones being sold can in fact kill your system! Make sure you are using a real Apple MagSafe power adapter. Its getting harder to tell the real ones from the fakes! Apple has stopped being aggressive on stopping the sale of these units as they are migrating to USB-C chargers so their more of them out there now.
I strongly recommend you get a real unit from a real Apple Store or directly online from Apple to be sure. Yes, they are more expensive! But they are cheaper in the long term if you then need to get your logic board replace or repaired from their damage.
Here's Apple T/N on what you'll need: Find the right power adapter and cable for your Mac notebook
Replacing the MagSafe 2 port:
Review this IFIXIT guide: MacBook Pro 15'' Retina Display Mid 2015のロジックボードの交換 Jump down to Step38 after lifting the display cable you’ll see the DC-In board just below. Here is the correct part: MacBook Pro 15" Retina (Late 2013-Mid 2015) MagSafe 2 DC-In Board.
MacBook Pro 15" Retina (Late 2013-Mid 2015) MagSafe 2 DC-In Boardの画像
製品
$29.99
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
i trust i fix it , more then apple i am jsut waiting for money to come and gonna buy from the site , charger and the logic board , ... But i got one more question why do i need to buy whole logic board , My only macbook charging port is damaged
さんによる
This series has the charging port as part of this smaller board unlike the older models which you can see here: MacBook Pro 15" Retina Display Mid 2012 MagSafe DC-In Board Replacement. And I agree the older design was better & cheaper!
さんによる
コメントを追加
I am confused, youre desdribing how to change the ports on the other side, not the charging port…. can anyone please help with that info?
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
@emptyvessel - So sorry, I don't know what I was thinking! I've corrected the info.
さんによる
Great! looks like it s out of stock there... any other links or reputable places youd recommend? Also maybe im missing it but the guide appears to be for a logic board.... thnaks!
さんによる
さんによる
theres a lot of scathing reviews of that company... Im guessing you wouldnt have a way to know that that particular part is legit? thanks again
さんによる
コメントを追加
I just want to say how disappointed I am with Apple. I have had 3 MacBook Pros that have had the same problem. The prongs is the plug part that attaches to the computer goes bad and will no longer charger. Every time I turned it into warranty they told me the plug-in wasn't covered and I had to buy a $80 charger. They even totally replaced the computer once. They said it was the electrical current in my house. Through searching the internet I found something surprising. A person had posted this in the apple community but apple deleted it. You can find this problem all over the internet with MacBook pros. All you have to do is clean the plug-in and the plug-in port with alcohol and push on each of the prongs until they all pop up. The problem is that the prongs gets stuck down. I have probably bought 5 chargers due to this problem. Please pass this information on as apple doesn't want anyone to know it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@jrhmds79 - What are you talking about??
The MagSafe charger does not have prongs that goes into the computer. Are you talking about the AC plug part?
How about telling us your exact model and take some pics so we can see what your issue is. We might even be able to help you! Adding images to an existing answer
さんによる
コメントを追加
回答を追加する
kuldeep さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 23
今までの合計 8,764
