メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年にAsusから発売されたタブレット、Memo Pad ME172Vの修理およびトラブルシューティングのヘルプです。
Broken Power Button After Dropping Tablet
So I dropped my tablet and now it won't turn on... I tried charging it and holding the power button but it won't work! Help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Hi,
Is the Power button literally broken or are you just saying that the tablet won't turn on when the button is operated?
Do you get any indication at all the the tablet has some functions working? For example, when the charger is connected, does the tablet show that it is charging
You may have to open the tablet and do an initial visual inspection, to see if there is anything obviously damaged due to the fall.
Here is a link to the Asus Memo Pad ME172V - LCDディスプレイの交換 repair guide which should be of some help.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
When I charged it, nothing would show...
The power button was pushed in before but it still worked. It doesn't work/react now.
Doing both at the same time also doesn't work...
Did I mention that the screen is shattered?
I'm sorry if this information does not help much...
What should I do?
さんによる
Hi LL Awesome,
Having a shattered screen is certainly not a good start. Presumably the tablet has been dropped
I suggest that you open the tablet as shown above and see what internal damage has occurred and progress from there as to what to do next.
さんによる
コメントを追加
You're going to have to remove the plastic power button to see underneath and actually press it yourself
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
LL Awesome さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 19
今までの合計 3,320
