メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Elephone P6000 Proは2015年8月に発売され、3GBのメモリとオクタコアMT6753プロセッサを搭載しています。
Is it possible to replace USB port?
My elephone p6000's USB port has been damaged to the point that has felt from the motherboard that it used to belong to. I have seen some sites that sell a USB port for this specific model, but I am wondering if it is possible to replace it for a new one for a regular user and, if so, which procedure should I follow, since AFAIK there's only a teardown guide explaining how to disassemble Elephone p6000, but does not mention anything specifically about USB port, other than it belongs to a secondary board (visit step 3: Elephone P6000 proの分解 ).
Thanks in advance
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
It depends on what you mean by regular user.
The process is quite simple: you just unsolder the old port and then solder a new one. There are plenty of instructions. Just make sure that you follow the instructions.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for your answer, George! Could you please tell me where are those instructions you are refering to? Although I am quite new to iFixit (just registered), AFAIK there's only a teardown guide explaining how to disassemble Elephone p6000, but does not mention anything specifically about USB port, other than it belongs to a secondary board (Elephone P6000 proの分解).
Since the USB has fallen apart from it, I was wondering if I can just simply plug a new one or I have to replace the secondary board.
さんによる 共有
コメントを追加
Its possible but you'll have to find someone who can do it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Carlos さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 30
今までの合計 1,152
