メインコンテンツにスキップ
Sony Xperia Z3 発売日:2014年9月(グローバルモデル) 日本国内取り扱いキャリア docomo(SO-01G)・・・2014年10月23日発売 au(SOL26)・・・2014年10月23日発売 Softbank(401SO)・・・2014年11月21日発売
114回答 すべてを表示
Z3 backlight/display issue after submerging in water?
So I have run it under tap water a few times but it would still work after that. But after submerging (in an attempt to show off my phone, quite embarrassing) it in water for a while, the indicating paper turned red. Moments later condensation appeared in both cameras, flash and indicator, screen flickered when I did a hard reset.
Few days in rice, condensation disappeared and the screen is just black. I have tried Sony PC Companion repair tool. The notification LED flashes and I can hear sounds from the phone responding to my touch.
Does it sound like a software or hardware issue? If it is the former, is there a way I can fix the backlight/display myself?
Should I give it a try?
Phone is still recognizable by my PC.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi
As you have now found out water and electronics and electricity are not a good mix.
The minerals in the water, cause corrosion and the water also provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts immediately and will not stop until it has been thoroughly cleaned away.
Rice is good to eat but does nothing to fix the problems caused by corrosion
Don't Put Your Device in Rice. Here's Why...
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to completely dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available from most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% or less, can also contain scents and is not as effective. If you do check the label to verify the amount and ingredients
Here is a link that in general describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Here is a link to the ifixit Sony Xperia Z3 LCD &デジタイザの交換 guide which may be of some help to you.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Jack Nicolsen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 884
