Always shows error of paper jam
As soon as the device is powered on the printer shows error paper jam. Full disclosure this issue started to happen after a cat peed on it. It worked for a couple of days and now it is showing the same error again
cat pee is acidic. this must have caused some parts in the board to corrode and shorted out
このアンサーは役に立ちましたか?
Firstly, why did the cat pee on it?
Secondly, since something is shorted you should check for anything that seems broken and replace it.
Was house sitting a friends cat. He must have been confused or something to something so random.
I suspect something similar too. Will have it checked.
I was hoping that I might discover a simple hack that can resolve the issue.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 1,016
