My screen is stuck on
when i turn on my screen it it stays on the screen that said voyager .
Courtney Lord sounds like your tablet has issues with the Android operating system. You may have to try a factory reset by booting into recovery mode. Powered the tablet off making sure you have more than 50% charge on the battery. Boot into recovery mode by pressing and holding the volume up and power buttons. At the RCA logo screen, let go of the volume up button and you should see an android image. Press and hold the power button and tap the volume up button once more and you should be in the recovery mode menu. From here, you will need to use your volume up and down buttons to scroll and navigate to the wipe data/factory reset option and use the power button to confirm. When the process is done, go ahead and reboot and your tablet it should now be set to factory original settings.
このアンサーは役に立ちましたか?
I did all the reboot and table hard reset but the keys will not work on my tablet
Same thing happening to me
I was dumb enough to buy a second rca tablet for my grandson only to have both of them stuck in limbo...the reset does not work on either one...everything was tried just as told but same screen...they will not go to any other screen...
It worked thanks!
Press the power button, then volume up, then volume down. Then wait.
このアンサーは役に立ちましたか?
What if I don't have keyboard?
You don’t need a keyboard. Use the PHYSICAL buttons on the tablet.
It worked. Had to do it a couple times but it worked. Thanks!
What you are gonna want to do is,
このアンサーは役に立ちましたか?
How long does it usually take to get passed the voyager screen after I do all of that?
My rca touch screen is not working I factory reset and reboot and still the screen is still locked
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 22
今までの合計 17,839
6 件のコメント
how do you fix it
Natalie Shrum さんによる
I did all of that and all it does is turn back off it's still not working don't know what to do at this point HELP PLEASE…..
Quoia Robinson さんによる
Same here. Piece of junk
Leslie Cobb さんによる
when the tablet gets stuck on the rca screen how do I fix that
Cari'Yhana Pinkney-Stalling さんによる
how to fix a rca screen
Joshua Davis さんによる
1以上のコメントを表示
