メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
Avoid dust installing a new screen
Hello
I had to change my Iphone 3G screen after a white screen of death, and everything works fine. The thing is that after the replacement some dust is between the touch screen and the screen. I tried to clean it but without sucess, i cleaned old dust but i get new.
Is there any trick to avoid dust? or maybe a way to remove it, compressed air?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hey there,
A new screen as in the hardware screen or the cover screen that protects your iPhone from your finger prints?
If it is applying the screen to protect the actual screen from your finger prints, there is a website:
http://www.ehow.com/how_5942211_put-scre... (credits to them, I did not write this, although I wish I did =P)
If you're talking about the actual hardware of the iPhone screens: I suggest you take a look at:
http://www.wikihow.com/Fix-an-iPhone-3G-... (If in this case, you want a screen replacement)
iPhone 3G Troubleshooting (Some of the frequent problems that occurred on iPhone)
And there are also some resources about taking the iPhone apart and replacing it with a new screen on the ifixit.com
iPhone 3G Front Panel Replacement
Things you might need to buy:
[リンクされた製品が存在しない、もしくは無効: IF137-007]
I am sorry I can't actually help out with my current resources, but If I am talking about something totally different, you can re-post your response and I will do some more research about it.
I hope I helped,
thanks!
Nonth =)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
When installing a new screen its best not to remove any protective films untill right before you put it in.
I find that using a microfiber cloth tends to work best.
After wiping it down, keep it covered by the cloth, and then wipe the LCD with the another cloth.
Then (as i said above) give them both a quick wipedown and install them.
By wiping them both right before you close up the iphone you are making the time it takes for dust to accumulate shorter and therefore eliminating most of the dust under the screens.
Hopefully this will prevent any dust getting in, but its not fool proof. Its just alot of trial and error.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
krasny oktyabr さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 2,713
