When hit start button it starts beeping.
When starting it starts beeping
この質問は役に立ちましたか?
Switch off the system; remove the battery, ac adapter and the power cable. Press and hold down the power button for thirty seconds to drain any excess static power.please pay close attention to the number of beeps. There is a big difference between a “beep-beep-beep” beep code and a “”beep-beep” beep code. Let us know how many times the system beeps.
このアンサーは役に立ちましたか?
I have the service manual. if you like please give me your e-mail
you take the cover off of the middle and take the ram out and put it back in I had the same problem
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 376
2 件のコメント
Hi!
Add some more details, like the system specs, OS. Also it would be great if you could tell us how many times it beeps and if there's a pattern.
Alex Niculescu さんによる
could possibly be bad ram
daniel さんによる
