メインコンテンツにスキップ
2015年3月のアップデートではアップルの13インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
623回答 すべてを表示
Why do my internal keyboard and track pad both become unresponsive?
This is the details on my system:
MacBook Air core i5, 1.6 GHZ 13' (early 2015) (I5 - 5250) Model: A1466 (EMC 2925)
ID: MacBook Air 7,2
Maybe last night, I spilled my system but it's only very little spilled water like one or two drops water and I wiped it as fast as I could.
Everything was fine and suddenly my trackpad and keyboard are unresponsive. And There's like some pop up message tells me that its searching for bluetooth keyboard & trackpad.
I tried to shut down by pressing the power button in about 10 sec, when I tried to open up again and press the power button nothing happens, system is now totally dead!
Both of my internal keyboard and trackpad become unresponsive, including my power button. So now I can't log in or even do anything.
So stressfull about this. Could you give me some advice?
UPDATE
Today I tried to connect the charger cable and MagSafe LED indicator shows orange and it's charging. Does that indicate that my battery is not the problem?
I do a method that I got from YouTube, I press the PB for 10 sec then I plug in my MagSafe cable in, the green LED indicator didn't show on, but when I released the power button, the green LED indicator shows up. Is this indicating that my keyboard is responding?
What happen to my Mac and What should i do? Thank You.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Hi,
So after 6 days, I just got my MacBook back to live again!
So here's the answer.
I bring my MacBook to service center in Indonesia, they checked it and then turn out that my Flex Cable 593-1604-B burnt. That's why my MacBook can't turn on normally. Then he checked the water damage, but there's no corrosion in my MacBook and Logic Board seems good. So they change the cable, it only cost around 45$, seems the cost better than to change the logic board i think.
Thank You all for the respons.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
What could have happened was the keyboard cable got disconnected or cut. A similar thing happened to my MacBook Pro. What you can do is unscrew the bottom plate, and when the computer is plugged in, create a short between these two pads.
This will basically be the same as pushing the power button. If you want to repair the keyboard and trackpad, unplug the battery and power adapter. The battery connecter is located on the far left beneath the power pads. Check the other cables next to the battery connector for breaks or if they're disconnected.
and if they are fine that must mean that the cable has been broken further along the line. To find the break you have to remove the logic board. Just Google 'how to remove logic board on macbook air 13'. Hope that fixed your problem.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Be careful here! There are a few different MacBook Air's as such the Power Pads are not all at the same location.
Until we get the OP's exact model its a bit of a gamble to point to locations on the logic board to poke as it could cause damage.
But you do have the right idea on how to diagnose things.
さんによる
Hi, thank you for the respons.
Please check it out. I just give some details about my MacBook.
さんによる
コメントを追加
回答を追加する
Clara Angela さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 491
