メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Cheap shielding from ham radio?
Hey not exactly a "computer" question but any idea of how to shield electronic devices (cell phone, wireless printer, tv signal box, etc.) from ham radio interference? Trying to be cheap and filing a civil suit is out for lack of money.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
I would talk to the radio operator. It is much easier for him to fix the problem. He may be unaware that his transmissions are a problem.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
I agree! Do this first. You should be able to find them looking for the large antennas.
さんによる
If interference is so strong you can hear a call sign, you can look up the person at http://wireless2.fcc.gov/UlsApp/UlsSearc....
さんによる
コメントを追加
You probably could make a Faraday cage, basically a metal screen that is grounded, and put that at the location where the ham radio is interfering with your devices. You can also contact FCC if the neighbor's ham station is causing problems that effects others.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Contacting the FCC should be your last resort.
さんによる
Don't forget radio waves travel around corners :-)
You need to have a full encasement of the faraday cage to gain its protection. Which makes it comersome trying to protect devices which also need radio signals (Cellular, WiFi, Bluetooth...)
さんによる
コメントを追加
Try talking to the radio operator, most are quite friendly and more than happy to help you out. Sometimes it is as simple as pointing the antenna in a different direction. Most problems are from poor shielding or grounds on your end. T.V. cables are very bad about the shield not grounded to the connector properly. This will allow everything to interfere like touch light dimmers, fluorescent lights, CB's on the interstate etc.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
al_estes1 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 25
今までの合計 541
