The screen tapping by itself
The screen keeps tapping by itself after I got a new screen put in
この質問は役に立ちましたか?
この質問は役に立ちましたか?
There is a temporary fix. Basically, redo the steps here
Make sure you put the screws in the proper place, this is an easy mistake that's costly.
You may also want to inspect the cables for damage.
Right after you put back the cables after disconnecting it should temporarily correct the issue. If it does not the part is damaged OR if the screws were misplaced then the unit is damaged.
I also state this is temporary because there is a slight chance that it will return more or less due to the part/or board being the issue.
Give it a try and let me know! Hope this helps
このアンサーは役に立ちましたか?
I didn't fix the screen myself
If its a repair shop take it back and make a claim. Especially, if you paid for it.
Redoing the installation may also correct it, and that will determine if the screen is faulty or done poorly.
Good Luck Friend
Either a bad screen or screen was forced in with dented corners of metal iPhone housing frame.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 107
