メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
What is the rear microphone for?
Hi,
I'm facing troubles with my iPhone 6 while making a phone call.
The people I call tell me that they hear me quiet and interrupted.
I found out that they here me good when I place my finger on the rear microphone.
Also facetime calls work. Mobile calls with speaker also work.
So when I place a sticker on my rear microphone people hear me just fine.
I already restored the iphone and did not load a backup. So it isn't a software problem.
So is the rear microphone broken or could it be something else.
Thanks!
Update (13.09.2017)
Unfortunately the problem returned after two days.
I repeated what I have done before, but that did not help this time.
I already changed the power flex cable (it has the rear microphone on it) but the error still remains.
Is there something else I can do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
I'm not sure how that helps because bottom microphone is used when making calls with speakerphone not enabled.
It's the filter near the headphone jack that needs to be cleaned most likely. Probably clogged up.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The bottom microphone is cleaned. When I but a finger on this one, no one hears me, as expected.
"Closing" the rear mic (between LED and camera) makes the call louder.
Maybe the rear mic does the noice cancellation and this does not work properly because it is broken. I don't know.
In which cases is this mic used? Is there a way to test it?
さんによる
コメントを追加
I fixed it, I don't know exactly what fixed it but here is what I did:
I opened the iPhone, disconnected the display and the powerflex cable. Cleaned everything with compressed air. Reassembled. Turned it on and tried it again. And now it works.
I did not disconnect the battery, so it was not a power disconnect.
Maybe dust or the powerflex got loose.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The rear mic is used when recording video, and I also believe it is used for noise cancellation. I would see if the mic picks up ok when recording video with the rear camera.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks, I tested video recording. It works just fine.
I thought the problem must be this mic, but maybe it's not.
I don't now how to continue finding the bug.
さんによる
コメントを追加
回答を追加する
h4nc1 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 8,243
