Mode dial not functioning
The mode dial (pos 10 in pict.manual) appears not to function, after selecting a position, the camera remains in automatic mode, dial moves in a sticky way.
any solution?
Thanks
Paul
この質問は役に立ちましたか?
any solution?
Thanks
Paul
この質問は役に立ちましたか?
By using contact cleaner spray to the dials and buttons, after which I applied compressed air in order to dry the areas, problem was solved. Had to do it a couple of times
このアンサーは役に立ちましたか?
Makes a lot of sense what you tried, although I would have used rubbing alcohol and no compressed air. Good job, you figured it out yourself.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 31
今までの合計 1,399
