Is a bent huawei p10 fixable?
Huawei p10, bent from the top left corner. The front glass is broken and sim slot doesn't work but rest everything works. Is it fixable? If it is, is it a feasible solution or its better to buy a new p10?
depends on your technicians.
you could replace the Housing, sim tray and screen.
These parts would cost around 250$ CAD To purchase, assuming you can find them at the same source.
A lot of labor is involved, and you're likely looking at arounf 450$CAD or more for a repair from a shop.
このアンサーは役に立ちましたか?
Can you unlock it
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 1,661
3 件のコメント
how do you bend a phone?
Vinicius Lupas さんによる
That's literally what I asked when he posted his question, but I deleted it because I was affraid that @mayer might get upset :))
Alex Niculescu さんによる
@alexniculescu You provide excellent answers. I may make a suggestion to you once in a while as to how to improve it but I try to make it as constructive criticism . If you look at your activity page and votes, you will see that 41% of all your up votes are from me.
@theelitepro_gd You were not making good answers at all nor were you even thinking, so I jumped on you hard because you did it so many times.
The most common way to bend a phone is to put it in your back pocket and sit on it. However, I've also seen it happen when a horse stepped on it while in the back pocket.
mayer さんによる
