メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
UE Mini Boomは、充電式バッテリー、スピーカーフォン機能、ライン入力、頑丈な設計を備えた非常にコンパクトなBluetoothスピーカーです。
Battery replacement for UE Mini Boom?
Is it possible change battery on this device? If yes do anyone know how to do it.
Thank you very much
Update (08/28/2017)
Thank you very much for your help.Well i'v seen already this movies and i manage to open it,also i check the port and looks that the power is coming in,also i took out the battery and test it separetly with external charger and it shows that it charging.How ever when i put every thing together it doesn't show any signs of live.Any way if any body know how to deal with it i will very much appreciate
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Getting into the UE Mini Boom is not that difficult, and soldering in a new battery should be easy; but what to replace the battery with? I've got model S-00136.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Sorry we don't have any IFIXIT guides for the Mini Boom. Here is a good YouTube Vid that shows a person opening one up: How to open logitech mobile boombox for fixing & UE Miniboom reassembly
Once you get it open you should be able to check the USB port to make sure its working using a Volt meter often the port breakdown so the battery won't charge. If the battery its self is bad you'll need to search the web for a replacement using the info from the battery. Good Luck!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
S.Goland さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 26
今までの合計 4,497
