Screen replacement on a TAM
Greetings.
Is there a guide available to replace the screen on a TAM?
Thank you for any information.
この質問は役に立ちましたか?
Greetings.
この質問は役に立ちましたか?
Surprisingly the one guide we have will get you there!
Here is the guide: Twentieth Anniversary Mac Teardown. Follow it thought to Step9 to get the front off which has the LCD screen mounted.
Just be careful you get the correct replacement display, you can't substitute.
このアンサーは役に立ちましたか?
Just to confirm, please: ALL steps through step 9 are required? (Thank you for your response.)
We just don't have a proper guide, yes I'm sure a few of the steps could be bypassed. As you go thru the task how about creating a guide ;-}
Hang on to this machine, it's one of the few older ones that retain real collector value. I think there were only 10 or 12,000 of them made. I only know of one in my town.
Agreed! Its a collectable.
Thanks, guys. Yes, I intend to keep it. It is iconic ... in its own rather eccentric way. (I'll try to complete a guide; however, I think I would end up plagiarizing most of Dan’s guide. If I’m successful, I will be sure to note proper attribution.)
過去 24時間: 0
過去 7 日: 2
過去 30 日: 23
今までの合計 1,146
