メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How can I unlock my iPod
My little sister was play with it and lock it. I forgot my combination and can't unlock it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
2 件のコメント
ive down loaded some music and turning it back on its showing the padlock feature and i cant unlock it ...how do i unlock it
さんによる
It may also be called _volumelocked
さんによる
コメントを追加
3件の回答
ベストアンサー
Here is a link to Apples procedure for setting and removing the lock. Please note you will lose all your data. Good luck.
http://support.apple.com/kb/ht1350
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
rj713 is of course absolutely right. There is a also another way to reset it without losing the data from your ipod :
first plug in the ipod, go to my computer, click on the ipod drive. Go to tools > folder options then click view. Click show hidden files,
Go to ipod_control, then go to device. There should be a file named "_locked" delete that. Now unplug the ipod and you should be ready to go
Good luck
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
didn't work so don't konw
さんによる
it did not work
さんによる
This Helped Alot Thank You
さんによる
It worked for me thank you a lot.
さんによる
コメントを追加
Go to Ipod folder in computer make sure hidden files are displayed
go to
-ipod_control
--Device
---_locked
don't delete it, just change it to un_locked
worked for me many times, just don't know how to full remove code or change it without restoring ipod
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Telling her how to show the hidden files would greatly improve your answer.
さんによる
This actually worked for me! In explorer go "View > Hidden Items" and uncheck it. Then go to the folder "IPod_Control" and do as described above.
さんによる
コメントを追加
回答を追加する
melissa さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 8
過去 30 日: 24
今までの合計 15,230
