メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.2 GHz (Turbo Boost up to 3.4 GHz) もしくは2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
Constant buzzing sound from right speaker
Hello,
A few weeks ago my MacBook fell from the front passenger seat when I slammed on the breaks and then it started making a crackling noise every once in a while.
It sounded like this https://www.youtube.com/watch?v=rx7Nwp9S...
And now its gone worse, it has a constant buzzing noise through the speaker and even when I plug in my earphones in the headphone jack. And the noise increases and decreases by changing the volume.
However when I plug in a thunderbolt dock, the noise goes away.
https://youtu.be/B-hlTRGn4nc
Now, is this something that is user serviceable? If so, which parts and tools do I need and can I get them from iFixit?
Thanks for any suggestions.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
bump................
さんによる
コメントを追加
3件の回答
ベストアンサー
Here you have a the removal process for the speakers and here the parts to buy to replace it. Is hard to say that your problem is other than the speakers. It does not cost you much to try and see if this will do the work>
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for the reply.
Just as I was going to place the order, I checked the speakers again because I had put the sound balance all the way to the left, and surprisingly its not buzzing anymore. This doesn't make any sense.
Everything is back to normal and its not even making that crackling sound anymore.
さんによる
コメントを追加
Found this thread on Google; figured I’d leave my comment here in case someone else finds it useful.
My right speaker started crackling shortly after I replaced the battery in my 2014 MBPr. It turned out that I had accidentally pinched one of the speaker wires upon reassembly. Applied some tape and tucked the wires under the screw mount and all is well again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
For replacing the left speaker, is it really necessary to strip it down completely? I dont want to remove the battery or anything, its all good.
Is it not possible to get the speaker out without taking out the main board first?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
ok, I disassembled the whole Mac and then replaced the old speaker with a spare one, it now works again.
さんによる
コメントを追加
回答を追加する
A AM さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 24
今までの合計 33,658
