Computer shuts off very frequently.
My computer turns off itself very often. Some times stays on only for seconds .
It is probably an overly sensitive heat sensor. You should contact Dell tech support and see if your computer is in warranty. The warranty is one year unless you buy an extended warranty. The problem is mostly likely to be the mother board.
このアンサーは役に立ちましたか?
I had this problem too. In service cleaned it, changed the silicon paste. And it work nice.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 158
