Phone Won't Turn on
I just replaced my digitizer and now the phone will not start. It shows an orange led in the speaker when charging but that's the only sign of life it has. Is there a connector I could've missed? Any ideas?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The screen itself uses a single LCD ribbon cable where the digitizer is together plugged into.**
Double check if the LCD ribbon flex cable is plugged in fully.
このアンサーは役に立ちましたか?
Only one cable connects to the motherboard correct? The second cable is already attached to the "main" cable that you plug into the motherboard. The "main" cable is fully plugged in.
You are right. I haven't done a HTC One M9 screen replacement in a long time. I have like 3 screens sitting in the stock.
Orange LED indicator means the phone can most likely switch on after it has sufficient charge.
Have you tried holding power button until it vibrates when on the orange charging led?
You should be able to hear sound from it when it boots up (unless you put the phone in silent mode).
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 935
