help my sega dreamcast wont read games anymore
i put it games and it wont load how do i fix this problem sonic adventure and jet grind radio are calling my name please help
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Alex, there are a couple of videos on youtube that may help you with that. http://www.youtube.com/watch?v=HTMSRfEqW... is one of them as a rule of thumb I would get a can of air duster and try blowing out the whole laser assembly including the gears and track. I'd also clean the center spindle (with rubbing alcohol on a q-tip) and make sure the discs are sitting flat. Just in case you need to replace the drive here are the instructions Sega Dreamcast GD-ROMの交換 good luck and happy gaming. Keep those legacy devices going....:)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 54
今までの合計 20,200
