メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Chevrolet Equinoxは、General MotorsのTheta unibodyプラットフォームをベースにしたChevroletのコンパクトクロスオーバーSUVであり、2005年モデルとして2004年に発表されました。
How do I disable the TPMS?
I have a 2010 chevy equinox and my TPMS light won't turn off even though all of the tires are perfectly fine. I have my inspection coming up and want this light off, is there a way to disable this feature? thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
7 件のコメント
my tmps light is on but the light wont go. i hv tried all possible means. My suv is chevy equinox 2013
さんによる 共有
can you help?
さんによる 共有
i dont have the psi indicated on the dash board if i use the method above> none of them shows i see the four places empty. when i took it to chevy dealer they told me it is the left back sensor that cant respond after replacing it still same
さんによる 共有
All my tiremoniter stopworking all sametime Ireplace all of them they still not working
さんによる 共有
All my tiremoniter stop working sametime. I replace all of them but still nothing works .how to repair
さんによる 共有
2件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
Monica Sanchez start off by trying to reset the TPMS :
WITH STANDARD IGNITION:
1. Apply parking brake.
2. Turn ignition to ON position (engine off)
3. Press the MENU button on the DIC (located on instrument cluster for all others) until the vehicle's tire pressures are displayed.
4. Press Set/Cir . Vehicle asks “Are you sure that you want to relearn?” Select Yes.
5. Starting at LF tire, decrease air pressure until horn chirps. Repeat procedure for remaining tires in the following order: RF, RR, and LR. After completing LR tire, horn will sound twice.
6. Turn ignition to OFF position to exit vehicle learn mode. Adjust all tires to pressure listed on tire placard.
WITH PUSH-BUTTON START:
1. Press and hold the push button start until the vehicle is in accessory mode. Note: on Cadillac models you will know when you are in accessory mode the Cadillac emblem appears on the DIC.
2. Press the MENU button located on the turn signal lever until “VEHICLE INFORMATION MENU” is displayed.
3. Once you are in the VEHICLE INFORMATION MENU, use the ^ v on the turn signal level until the DIC displays the vehicle’s tire inflation pressure and positions.
4. Press and hold the button located on the end of the turn signal level until “Are you sure that you want to relearn? YES or NO” is displayed.
5. Use the ^ v on the turn signal lever to highlight YES. Once YES is highlighted, press the button located on the end of the turn signal lever. The horn will chirp, “Tire Learning Active” will be displayed on the DIC, and the left front turn signal will be illuminated.
6. Beginning with the left front tire, use a TPMS activation tool to activate the left front sensor. Once the sensor has been activated, the horn will chirp and the right front turn signal will be illuminated.Repeat procedure in the following order, right front sensor, right rear sensor, and finally the left rear sensor. Once the left rear sensor has been activated, the horn will chirp twice. You can then turn the vehicle off to exit “learn mode.”
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Hi, Thank you for your answer! What if the horn never chirps even after I decreased the air pressure for a long time? I tried this method but the horn only chirped for the LF and RR tires.
さんによる 共有
It's my understanding the batteries in the sensors inside each tire are only rated for five years, so if I had to guess, I'd say two of your batteries are dead, which means the other two probably won't be far behind. Unfortunately, the batteries aren't replaceable (at least, not to my knowledge), so you end up having to buy new sensors and paying to have the tires dismounted and the new sensors installed.
さんによる 共有
Will this same process work on a 2018 Chevy equinox?
さんによる 共有
@dadibrokeit I've seen them go for 10 years on Hyundai/Kia cars. It depends on the brand as some last longer then others. Now I wouldn't be surprised if GM sensors only last 5 years as a cost cutting measure lol. Remember this is post GFC GM when they did away with bulletproof diesel motors and Allison trans, as well as unlikable gas engines like the 6L Vortec pushrod V8 which was LS based. New GM is 2007-presnent.
For real if I had to pick between a new GM or an old Allison trans diesel like the 2006 2500HD I'm taking the 2006 2500HD ANY DAY. The main advantage is the Allison trans beats the 4L gas transmissions for longevity every time. They have typical GM electrical gremlins but they're 4-500k mile trucks, 600k+ if you take really good care of them.
さんによる 共有
コメントを追加
IF the tire monitoring systems were designed right, it should be able to be turned OFF, if the owner does not want that system
and he can monitor the pressure in the tires manually him or herself.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
my front left tire show a blank ....NO PRESSURE,,,..HOW CAN THAT BE LOWERED? MAKE S NO SENSE.
さんによる 共有
Im with John, the real question is why did they put it in in the first place?[profits from useless maintenance] because #1 anything with a battery will eventually fail. #2 to replace faulty tpms involves removal of wheel and breaking the tire bead etc. At the dealer its over 75$ each.
さんによる 共有
Tpms were mandated by the us govt. It is considered a safety issue, as under inflated tires heat up and have a high likelihood of a blowout under conditions of hi speed or hi load.
さんによる 共有
@rogerthompson abso;lutely correct and hence TPMS can't officially be disabled.
さんによる 共有
コメントを追加
回答を追加する
Monica Sanchez さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 99
今までの合計 20,516
