メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
SonyのXperia Z5 Compactは、解像度720 x 1280の4.6インチIPS液晶ディスプレイ、クアッドコアのQualcomm Snapdragon 810プロセッサ、2 GBのRAMを搭載したAndroidスマートフォンです。2015年10月発売。
Notification led blinks 4 (four) times?
I was have problem with my lcd: there was picture but no backlight.
Then;
1-Pulled off battery
2 -Cleaned flex cables with alcohol.
3-Putted everyhing back.
4-Putted battery back.
5-Tryed to power on.
Now:
When i try to power on vibrates 1 time as normal and 5-6 seconds later red led blinks 4 (not three) times. No thing happens. If i try to shut down by sim slot button its acts normaly and vibrates 3 time.
Anyone knows what is the meaning of 4 time led blink.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Sony Online Support emloyees made me crazy. I find my own answer. When lcd or backlight is broken or cant work properly device prevents boot up. 4 time blinks wants to say that! Thanks for Sony's ignorant employees.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
i disassbemled my lcd's flex cable and phone booted up normaly (without picture of course.). I will buy new lcd.
さんによる
Did new screen solved the problem ?
さんによる
What is an icd?
さんによる
コメントを追加
I replaced the LCD screen and back camera. Now it won't boot up. There is no response at all from any of the reset option. The 120 second reset. The power+volume up, power+volume down. Nothing. When I connect to charger and hold down the power button, the red LED comes on for a second, then turns off, the phone vibrates 3 times followed by the red LED turning on again for a second and then turning off. Then the process repeats. Holding down the power or the 120 second restart button while plugged in yields the same results. I tried repair using pc companion, doesn't work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mehmed akif ay さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 5,105
