メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Performance Designed Products, LLC製のモデル番号064-015-EU-BLのPlayStation 3用ワイヤレスLEDコントローラー。
USB Not connecting to PS3
My PS3 afterglow controller has always worked great but recently the USB drive just stopped connecting. Now whenever I plug in the USB to my system it just continuously blinks. My USB ports are working fine because I can still charge other controllers and the actual USB to the controller connects perfectly fine to my PC just not my PS3. So I have no clue what the issue is and I don't quite want to get a new controller yet because it seems like this one still works, it just isn't connecting to my PS3 right now. It'll be great if someone could answer this
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
how u dont use the usb for ps3 and pc
さんによる
コメントを追加
1 件の回答
ベストアンサー
Check the pins on the controller's end of the USB. Are any of them bent or dirty? A short due to a bent pin or dirt blocking a connection could be causing the issue. It also would not hurt to give the controller's usb pins a cleaning with contact cleaner to ensure a clean connection. I would also recommend checking the cable itself, to see if their are any kinks in or exposed wiring. If that doesn't it fix it, then its most likely a problem within the controller's PCB board.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
What is a pcb board and how can i fix it or clean it so i can get the controllers to work
さんによる
コメントを追加
回答を追加する
Ty Smothers さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 12,691
