メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ソニー製ステレオヘッドホンMDR-ZX100 ZXシリーズ。
Both the speakers are not working
Both the speakers are not working and I have checked the whole wire and it is working for another speaker and I have connected the speakers with another wire it not working...hence the problem is with my speakers. Please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
nitheesh k unlikely that both speakers have failed. Check the 3.5mm plug. Check it and replace it as necessary, follow this guide Skullcandy SCS-SCBP SKULLCRUSHERS 3.5mmプラグの修理 to do so. Different model headphone but identical procedure. you can also check the wiring to the drivers (speakers) by using this guide Sony MDR-ZX100の修理方法 and measure continuity with a multimeter from the connector to the drivers.
Skullcandy SCS-SCBP SKULLCRUSHERSの画像
ガイド
難易度:
中レベル
45 minutes - 1 hour
Sony MDR-ZX100の画像
ガイド
Sony MDR-ZX100の修理方法
難易度:
中レベル
15 - 30 minutes
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The problem is most likely with your speakers, but it is unusual that both speakers fail together. Are these speakers connected to a computer? Such have a power supply inside one of them and if that fails the speakers do not work. As most of these have an external wall-plug supply, check this (measure voltage at the output plug). If there is no voltage just replace the "wall-plug" supply with one of the same voltage and Ampere rating.
If your problem is with regular speakers that you connect to am amplifier I have no idea what may be wrong with both of them.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
nitheesh k さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 363
