メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Intel Core 2 Duo T5500 1.66GHz、512MB RAM、80GB HDD
computer wont turn on
my computer shut down suddenly, no warning, then would not turn back on. i replaced the battery and power cord. still wont turn on. why?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
If you don't see brand logo at start, your motherboard or one of your RAM stick or your GPU is potentially dead. Try to test the computer RAM stick first (by testing computer ram stick(s) one by one then start the laptop). Then test the motherboad if it doesn't work.
If there is no reaction when you push the power button your motherboard is dead.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I would try everything @andnerb mentioned and if you get the laptop to post, try running Dell's internal diagnostic test. It is accessible by hitting F10 after booting bios. This allows you to test each component for failures and helps with troubleshooting problems.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Not sure if F10 works on a D520. If the hard drive is toast on this model, you can't get to the hidden partition on the drive, where the test software is located.
さんによる 共有
Huh. I've been able to access the preliminary Dell diagnostic tests from several latitudes and Precisions without a HDD installed. The special partitions on the HDD are usually dedicated for drive recovery, driver backup and dell system recovery tools.
さんによる 共有
It depends on how old the machine is. D520 was a Core 1 or possibly an early Core2 depending on how it was configured.
さんによる 共有
コメントを追加
回答を追加する
forrest garth さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 33
今までの合計 1,061
