メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年11月22日に発売された、Microsoftの第3世代ゲームコンソール。
How to re-install XBox one OS.
I know about the video in the guide for replacing the HDD, but I need to know how the Pro's (@tronicsfix and @tomchai, I'm looking at you) do it, preferably in windows. I have a new HDD for an new xbox one, and my old one from my personal One. Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 9
2 件のコメント
There is a YT video that explains how to put the Startup screen graphics back up.. but it involves copying the file onto the drive, so it might have to be pulled again (but it's just another 10mins work).
P.
さんによる 共有
I have a xbox 360 boot disc and im looking for a xbox 1 boot disc download so i can go back from xbox 360 to xbox 1
さんによる 共有
コメントを追加
3件の回答
ベストアンサー
I don't have a video on it. This is the best video that I know of for this fix: https://www.youtube.com/watch?v=GaKVBo3k...
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
Alright, I guess a video will do. Thanks!
さんによる 共有
Slap in a new drive, copy a recent Xbox OS onto a thumb drive, plug it in, hold the Bind and Eject button, and then Power button, listen for the beeps and follow the on screen instructions. the Restore Factory Settings zip file you have to get off the MS page: https://support.xbox.com/en-US/xbox-one/...
さんによる 共有
that will not work the harddrive needs partitioning before you can use it
さんによる 共有
コメントを追加
For Xbox One just add external drive. Replacing the internal drive is way too much hassle, does not save money and no guarantee it will work in the future.
このアンサーは役に立ちましたか?
スコア 4
10 件のコメント:
I mean I'm replacing a bad internal drive, on a cheap xbox I bought.
さんによる 共有
I can't guarantee anything but it is likely that the board and content on the drive are paired together or at least version paired. Xbox One was never designed to let users boot from a generic drive image and initialise itself so very low chance of that working, Most times you just get E200 error.
If you insist, try download drive dumps from other users that are willing to help or from another junk xbox, preferably try multiple OS versions, see if it boots. If it did not boot don't just try another dump, see if USB system update works and lets you reinitialise the console.
I actually never attempted messing with the Xbox HDD, I don't have junk consoles around to toy with and I don't want to mess up a good xbox.
さんによる 共有
No, I know there not paired. It's not as simple as that, either. I have my own Xbox, it started with E200 and all I had to do was scan and repair it in Windows. I've tried cloning it but that doesn't work. Guess I'll have to wait for @tronicsfix to sign on. Thanks anyway.
さんによる 共有
Maybe it's not individually paired but board firmware version has to match with OS version, or it's simply that existing personalized files from another console has to be deleted, thus the console reverts to factory mode and generates new files again. If the console does not do this on its own maybe forcing a USB system update will convince it.
Anyway I'll see where this is going, I'm waiting for the expert's idea as well.
さんによる 共有
I really wish people would not just make stuff up.. if you dont know, dont answer! hardware is not paired, nor indexed, or mated or anything.. slap in a new drive, copy a recent Xbox OS onto a thumb drive, plug it in, hold the Bind and Eject button, and then Power button, listen for the beeps and follow the on screen instructions. the Restore Factory Settings zip file you have to get off the MS page: https://support.xbox.com/en-US/xbox-one/...
1 hour ago by pahvasta
さんによる 共有
5件以上のコメントを表示
コメントを追加
I had my internal Hdd go bad , my tech guy swapped the hdd for a new one , did a couple off stuff on his pc and run the latest os update with a flash, and voala . The new hdd is readable . The only issue now is my console dosent have the xbox start up .it shows a blank screen and opens to the home page
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Did you have any issues later on with your new hdd?Did it actualize with Microsoft updates with no problem?No issues with game pass or live gold?
さんによる 共有
@gmdiver gamepass and live gold are subscriptions and literally have nothing to do with hardware or os issues. I have gold on 3 different systems, only one set as home, and have repaired two of those 3 systems myself without any issues from Microsoft
さんによる 共有
コメントを追加
回答を追加する
George A. さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 51
過去 30 日: 159
今までの合計 95,548
