メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Acer Aspire V5-573pgの修理ガイド、ユーザーマニュアル、サービスマニュアル。この薄型軽量の15.6インチノートパソコンは2013年から2014年にかけて製造され、日常使用を想定してパフォーマンスと携帯性のバランスが取られた設計となっています。
I think I need everything fixing.
Hello,
My mum has broken my laptop and there's visible damage on the edge near the keyboard where it's coming apart. When I turn it on it goes to this blue screen, not sure what it is but it doesn't turn on anymore. Prior to this it used to over heat I've had it since September 2015. I also have expensive software on it and some old work from my degree and was wondering if it gets fixed will it be wiped? Also, can you give me a quote?
Thank you,
Laura
Update (06/29/2017)
The laptop is not Acer Aspire V5-571.
It's a Acer Aspire F5-571 i5 "15.6
Not sure why it's showing something different.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
You'd charge 55 dollars to move data off a hard drive? Is that like 200 dollars an hour to take the drive out? Then twice as much more to watch a loading bar?!
さんによる
as stated below, you could take the laptop to his shop for data recovery but my question is what version of windows are you running, if its windows 10 you can just put the hard drive in another windows 10 computer and be good as new.
さんによる
コメントを追加
1 件の回答
ベストアンサー
There's usually there's a code that is displayed along side a blue screen, THEY_LOOK_LIKE_THIS. If you an take a note of that and let us know we might be able to help with a repair.
If you remove the HDD and buy a sata to usb cable you won't need to pay someone to recover the data.
As for the laptop, I'd let it go, get a new one.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
soloist さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 313
