メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年8月発売。モデル番号 Z796C で識別可能
Editing my contact information
Hi, I have a ZTE Majesty Pro LTE Z798BL. My service provider is Tracfone/Safelink.
I am attempting to edit my contacts. When I touch the screen, I get a message that says I have disabled required permission. What permission? And how do I re-enable it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 9
4 件のコメント
I also have this problem and can not find an answer.
さんによる
Yes help me remove message
さんによる
ZTE, never again. I can't delete numbers I don't want anymore. I hate this Chinese built garbage!
さんによる
My phone doesn't allow any contact to save
さんによる
コメントを追加
3件の回答
最も参考になった回答
go into your setting and enable the permissions for your contacts..should be in application settings
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
there are no permissions under settings, I have the same issue, there are no permissions under the apps either for this.
さんによる
I had same problem on new phone and stumbled around for several days. Then happened across this and turned on all permissions in contact applications and the edit now works. Now I have to figure out which permissions I can turn off!
Phil Starr
さんによる
Thank you Phil Starr, I turned on 'all permissions' in contacts an was able to edit my mom's ZTE cell. Thanks again!
さんによる
How do I find the contact applications so I can all he permissions?
さんによる
コメントを追加
These Instructions were given me by a Engineering Student (who will be designing Cell Phones) at Walmart in a Cell Phone Kiosk. It was for the ZTE ZFIVE G
Home, Settings, Apps -
NOT apps as I was doing.
Then scroll down to Contacts…
Permissions then…
Storage - Slide the slider thing to the right.
Hope this helps - (I mentioned to her that non of these instructions were “intuitive” - who would think of it and not mentioned in the booklet either - errr! Please when designing cell phones make it intuitive. MHO
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How to restore contacts
Update (09/01/2020)
It did not
Resore contacts
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
On cell majestic. Zte
さんによる
コメントを追加
回答を追加する
Elena Vaccaro さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 22
今までの合計 8,191
