メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル A1103 / 1.25、1.33、1.42、または 1.5 GHz G4 プロセッサ
Flooded Mac Mini Power Adapter
The area where I keep my mac mini was flooded with the mac mini turned off. The power supply was actually full of water as it was laying on the floor. After drilling a hole in the power adapter to drain out the water, and allowing it to dry out fully, it still will not power on the machine at all. What are the chances that only the power adapter is bad and not the mini also? There is no way to test it since I do not know anyone else with this same power adapter. Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Did your mini get wet at all? If not you should be OK.
The hard part is finding one of these older power bricks
さんによる 共有
Thank you for your opinion. I have found a power brick on eBay for less than $20.00. It is worth the risk to see if it will work.
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
afraid some items might been blown or shorted,
even that, water contribute oxidisation and corrosion to the electronic parts, circuits and traces.
maybe consider to get from ebay or... lend one 3rd party universal adapter, e.g. acbel, etc which can set around this range, Input:: AC100-240V (worldwide use)
Output:: DC18.5V 4.6A
Power:: 85W.
to test before purchasing it.
http://www.erepairstore.com/85w-a1105-ac...
Update (06/30/2017)
画像
i think the connection is slow... but a screenshot
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
@salmonjapan could you check that link, I can't get it to load
さんによる 共有
コメントを追加
回答を追加する
ndwig さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 452
