Display is completely black
When I start my notebook the display is completely black, I have already changed the inverter but the problem isn't resolved.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The problem can be the display, the graphics adapter or the mother board. If you connect an external monitor and it shows your desk top then you have a bad display. If you don't have an external monitor, use a flashlight angled to see if you can see icons on the desktop, this narrows the problem to a back light on the display. If none of these steps work, then you may have a bad mother board or bad graphics adapter. Shut down and remove all the memory and see if you get a beep error, a beep error will indicate that the mother board is working.
このアンサーは役に立ちましたか?
I must remove RAM ?
This is to test to see if the motherboard is good, if you get a beep error then the mother board is good. Still could be problem with graphics adapter that is also on mother board.
If mother board is working, how do I identify the problem?
I have remove RAM and I listen a beep
What do you suggest?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 781
